half duplex or full duplex configuration for MDS9124 management port?
dennis.dai
Hi All,
Is it possible to set the management port of mds 9124 about half or full duplex configuration?
I want to correct following error:
Jun 13 10:27:20.799 GMT: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet4/18 (not half duplex), with mtw1pc02bs0(FOX1450G8QG) mgmt0 (half duplex).
it seems mds 9124 set his port to half duplex.
Dennis
2 Accepted Solutions
deschamps
You may want to check this thread :
https://supportforums.cisco.com/thread/2059109
Else try the following :
switch# config terminal
switch(config)#
switch(config)# interface mgmt0
switch(config-if)# switchport duplex full
switch(config)# exit
switch#
switch# copy running-config startup-config
Also, I would suggest you check what the counterpart of your MDS switch mgmt interface is set to (i.e. is it set to autoneg, then try setting it to fix speed/duplex or the other way around).
Vincent Jamart
Hi Dennis,
You might have hit bug CSCte76880 (http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCte76880)
Configure both interfaces to auto duplex achieve a full duplex connection as a workaround, or upgrade to 4.2(7e) or 5.0(4d) where the fix has been integrated.
Best Regards,
Vincent
deschamps
switch(config)#
switch#
Vincent Jamart
Hi Dennis,
Best Regards,
Vincent
Kris Vandecruys
Hi Dennis,
is there a reason you're not using auto detect?
Hi Kris,
Becasue network admin told me that he got the error message:
Best Regards,
Dennis
