06-21-2012 01:05 PM
Hello
How to copy fcalias and zone information across ISLd switches?
Two switches that are ISL'd together. When I update the active zoneset the zoneset gets copied over to the new switch but I don't see the fcalias or zones on the new switch. only on the old switch where I created the zones. how do I copy the fcalias and zones over to the new switch?
Chetan
Solved! Go to Solution.
06-22-2012 06:28 AM
fcalias is distributed with the full zoneset, so disrituting the full zoneset will distribute the fcalias.
Zone Set Distribution
http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/sw/5_0/configuration/guides/fabric/nxos/zone.html#wp1753327
David
06-22-2012 06:28 AM
David
