Webcast- Automate Nexus9k
Community Member
How to factory default cisco MDS 9222i
Highlighted
write erase
write erase boot
reload
(If prompted to save run to start, say no)
http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/sw/4_1/configuration/guides/cli_4_1/bb.html#wp1087208
David
Community Member
Hi, Thanks for response...
One more thing.... I dont want the erase the management IP address , rest everything should revert to factory default, because i am doing it remotely i need to login... is there any way to accomplish this.
Abhilash
Community Member
If I do "write erase" whether this will erase the username / password also...
it will erase your password.
if you don't want to erase every thing, what you can do is, open  you configuration with notepad and put "no" in front of the  configuration line. and then paste it to the switch under configuration mode
4399
