HP Blade Cisco MDS 9124e
Hello all,
I got a new c7000 with some MDS swithes.  I'm trying to get to the latest software.  I started at 4.1.x and can only get to 4.2.9.  I'm then trying to upgrade to 5.0.4d it fails.  In Fabric Manager it fails during copying and when i try to install via CLI i get the following:
-- FAIL. Return code 0x       0 (success).
Install has failed. Return code 0x40930068 (Runtime check failed).
Please identify the cause of the failure, and try 'install all' again.
Currently i have 5.0.7 FM installed.  So question is can i get to 5.0?
Another question is can i get to 5.2.2 with using FM 5.0.7?  Or do i have to install DCNM?
Thanks for your time and support,
Nick
355
