Load 8 port lic
gkenny
I have an 8 port lic file on my laptop. How do I install the lic on a MDS9124 switch?
I have tried the Fabric MGR GUI and I get the following error “Error NotThisHost?
suntzzu
is this license specific to the switch in question?
mkoch
Level 4
Level 4
where did you get that license file?
These files are specific/locked to a certain MDS and cannot be copied from one MDS to the other.
regards,
Michael
I had the wrong host id in my lic file. I got a new lic file and it installed just fine.
When enter # show luc usage I see 24 port licenses, but when I enter show interface fc1/13 the response is port activation lic not available.
I also enter no shut interface fc1/13, do I need antoher command to active the lic on a per port bases?
Make sure you've added "port-license acquire" to each interface you've licensed.
It will look like this in the running config:
foobar-fcsan-sw1# sh run int fc1/16
version 3.1(2)
interface fc1/16
