MDS 9100 MGMT0 showing half duplex
My user has a Cisco MDS SAN module installed in a IBM Bladecenter chassis.
I took a look at the module's managment interface mgmt0. It's showing half duplex. The module does not allow me to change the duplex setting. According to documentation, duplex is auto sense.
The neighbor switch port is set for auto. It displayed "auto-full". I configured the switch port for full duplex. The mgmt0 interface still displayed as half duplex.
Anyone know of bug or issue with SAN mgmt0?
User has other modules same hardware and software version with no issue. We see full duplex on both sides.
sh version
Cisco Storage Area Networking Operating System (SAN-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2007, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software may be covered under the GNU Public
License or the GNU Lesser General Public License. A copy of
each such license is available at
http://www.gnu.org/licenses/gpl.html and
http://www.gnu.org/licenses/lgpl.html
Software
BIOS: version 1.0.12
kickstart: version 3.2(2c)
system: version 3.2(2c)
BIOS compile time: 09/10/07
kickstart image file is: bootflash:/m9100-s2ek9-kickstart-mz.3.2.2c.bin
kickstart compile time: 11/16/2007 12:00:00 [11/16/2007 23:23:43]
system image file is: bootflash:/m9100-s2ek9-mz.3.2.2c.bin
system compile time: 11/16/2007 12:00:00 [11/16/2007 23:49:32]
Hardware
cisco MDS IBM FC ("1/2/4 Gbps FC/Supervisor-2")
Motorola, ppc8541 (e500) with 515032 kB of memory.
Processor Board ID
bootflash: 250368 kB
B52EUP15-SAN2 kernel uptime is 234 days 13 hours 14 minute(s) 8 second(s)
Last reset at 636281 usecs after Fri Aug 1 08:20:47 2008
Reason: Feature NPV enabled
System version: 3.2(2c)
Service:
1 REPLY
Re: MDS 9100 MGMT0 showing half duplex
You might want to check with IBM as to the difference in the Blade Center Chassis. There really is no physical interface for mgmt0 on the 9100, it is connected to the internal ethernet switch or hub via the back plane connectors. I believe that this switch or hub is on the Management Module for the chassis.
Are the Blade Center chassis the same model?
Could one chassis have a newer version of the Management Module that perhaps has a switch versus a hub incorporated?
Because there is no console port, the configuration of the management interface is disabled. It obtains all of it's settings from the Chassis. Disabling configuration on the mgmgt 0 interface prevents a situation where an incorrect setting disables the interface locking out the user. With an external MDS, you have the console as a way to recover if the mgmt 0 ends up with a configuration problem, as a way to recover.
Hope this helps,
Mike
677
