mds 9124 and fabric manager problem
I have 2 mds 9124 that are working fine with the device manager, but for some reason, i guess security i cant connect with fabric manager, what lines do i need to add the configuration in order to use the fabric manager?
Thanks for all answers
1 ACCEPTED SOLUTION
Re: mds 9124 and fabric manager problem
If you go to the switches IP Address via a Web Browser it will show you want version you are running.
The Default username and password is "admin" and "password" and server address should be "local". After that you should get the Normal switch login credentials, the same as DM.
Do you get the First Login screen? If so that is a default username and password. You then get the normal login screen after that.
Also I had a problem connecting to DM & FM and that turned out to be "IP ACL", somebody had setup ACL and that was stopping us getting access from certain workstations.
Hope that helps.
Yep, i get the first login screen, but i get a connection error message when i enter the username & password. And its not an ACL. Maybe i have problem with the FM server.
What is the error message? Is this from the FM server or workstation?
What version of Firmware are you running?
What version of Fabric Manager are you running now? The Fabric Manager has two logins, the first being into FMS and the second into the seed switch. Have you tried the default login of admin and password at the first screen?
I dont know the version, cause i am not in front of the system at the moment. But the problem is with the first login to the FMS, what is the default login? and is to "localhost"?
thanks
900
