11-04-2008 09:28 AM
MDS switch rebooted with the following FATAL error.
show system reset-reason
Reason: Reset Requested due to Fatal Module Error
Service: OHMS daemon
Version: 3.1(2)
show module internal exceptionlog
exception information --- exception instance 1 ----
Module Slot Number: 1
Device Id : 0
Device Name : undef
Device Errorcode : 0x4073001d
Device ID : 07 (0x07)
Device Instance : 48 (0x30)
Dev Type (HW/SW) : 00 (0x00)
ErrNum (devInfo) : 29 (0x1d)
System Errorcode : 0x4073002a System Health failure
Error Type : FATAL error
PhyPortLayer : Management
Port(s) Affected : 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24
Error Description :
DSAP : 0 (0x0)
UUID : 0 (0x0)
Any input please..
11-06-2008 02:09 PM
How long was the switch up before it reset?
11-07-2008 12:50 AM
I am not sure about how long the switch was ON but as I remember, it was a new setup. So uptime can not be more that 2-3 Months.
11-10-2008 02:40 PM
Ok. It doesn't sound like the 497 day issue. Were there any core files or anything else in the logs? Was a case opened with Cisco support?
11-10-2008 02:43 PM
Also as this is Gen 2 switch, it doesn't sound like the know OHMS bug either. I'd recommend a case with Cisco support.
