MDS 9509 Memory
Can someone confirm for me whether or not the MDS 9509 supports a memory upgrade?
1 REPLY
Bronze
Re: MDS 9509 Memory
G'day,
Are you having issues that requires an upgrade? :)
You could prob upgrade it but its not somthing that you can buy a upgrade kit for... :)
And... you prob wouldn't be supported.
To be sure you might want to check your local SE
135
