Community Member
MDS 9513 FM Switch error
In Cisco MDS FMS running on Windows XP, I see errors same as "No Traps"under Status, and yellow marked.
Could someone explain what causes the error to come.
Keisikka
1 ACCEPTED SOLUTION
Silver
Re: MDS 9513 FM Switch error
As for the "No trap" warning, once that FM should register traps with Quail to get rid of this warning. Please see bug CSCei47755
This is the bug ID that documents the "warning, no traps" message.
CSCei47755:FM should register traps with Quail to get rid of the warning
info. The warning is due to the way FM polls the MDS to confirm the switch state. If something should really fail, it will report more than just that message. The "no traps" will show if you have not configured traps or if the FM database has not been updated with the fact that traps have been set up.
Silver
Community Member
The bug is only be viewed by cisco staff.
I'll try.
525
