Needing help on installing Fabric Manager 3.2.1 on WinXP. I can't run the file m9000-fm-3.2.1a.jar. I follow the instruction and installed Java 1.5, but still can not execute the install file. Really appreciated for any helps. Thank you.
I downloaded the 3.2.1 CD zip file (~430MB) and unzipped it to a folder I named C:\FM321. I then ran following command from windows cmd prompt to launch the FM installer.
