Nexus 5510/5520 ve 6100/6200 interconnect switches
axfalk
I understand the 6100/6200 interconnect switches are based on the Nexus 5510/5520, so what's the difference between them?
thanks.
_ Greg
Walter Dey
6100 is first generation, 6200 is second generation Fabric Interconnect.
5548/5596 (not 5510/5520) are also second generation.
FI in general has more flash, also runs Linux kernel besides NX-OS; it hosts the UCS manager application.
There is no feature parity between 6248/6296 and 5548/5596 !!
e.g. there is no CLI NX-OS set command support (only show commands are supported), all is either done with XML and or UCSM.
Walter Dey
axfalk
Thanks for your response...
