Nexus 5548 VPC issue
dclee
We have 2 Nexus 5548's operating in VPC mode for our VMWare environment. its been working well for quite some time now.
But I noticed that just recently VPC10 is down, which is our connection back to one side of our NetApp SAN. The physical ints
are up on both sides and all appears well.
NEX1# sh vpc brief
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 100
Peer status                     : peer adjacency formed ok
vPC keep-alive status           : peer is alive
Configuration consistency status: success
Per-vlan consistency status     : success
Type-2 consistency status       : success
vPC role                        : primary
Number of vPCs configured       : 9
Peer Gateway                    : Disabled
Dual-active excluded VLANs      : -
Graceful Consistency Check      : Enabled
vPC Peer-link status
id   Port   Status Active vlans
1    Po100  up     1,220-222
vPC status
id     Port        Status Consistency Reason                     Active vlans
10     Po10        down*  success     success                    -
20     Po20        up     success     success                    220
30     Po30        up     success     success                    1,220-222
NEX1# sh vpc consistency-parameters vpc 10
    Legend:
        Type 1 : vPC will be suspended in case of mismatch
Name                        Type  Local Value            Peer Value
Shut Lan                    1     No                     No
STP Port Type               1     Default                Default
STP Port Guard              1     None                   None
STP MST Simulate PVST       1     Default                Default
lag-id                      1     [(1, 2-a0-98-11-24-9c, [(1, 2-a0-98-11-24-9c,
                                   1, 0, 0), (7f9b,       1, 0, 0), (7f9b,
                                  0-23-4-ee-be-64, 800a, 0-23-4-ee-be-64, 800a,
                                   0, 0)]                 0, 0)]
mode                        1     active                 active
Speed                       1     10 Gb/s                10 Gb/s
Duplex                      1     full                   full
Port Mode                   1     access                 access
MTU                         1     1500                   1500
Allowed VLANs               -     220                    220
Local suspended VLANs       -     -                      -
interface Ethernet1/3
  description NETAPP_NODE_A_VIF10G-1
  switchport access vlan 220
  channel-group 10 mode active
interface port-channel10
  vpc 10
sh port-channel summary
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        S - Switched    R - Routed
        U - Up (port-channel)
Group Port-       Type     Protocol  Member Ports
      Channel
10    Po10(SD)    Eth      LACP      Eth1/3(I)
stanti
From the port-channel summary I see the physical port is in "I" state.  This usually means the port is not receiving LACP packets from the other side.  (operationally individual).  To confirm this, check with "show lacp counters interface port-channel 10"  and look for sent but no receive counters incrementing every 30 seconds.  If this is the case, then this means the other end of this port-channel is not correctly configured for LACP.
steveN
Oleksandr Nesterov
Please add following outputs from your n5k devices:
sh log log | i 1/3
sh log log | i channel10
sh int eth 1/3
sh int po10
also please check physical connection and cable run. Such unexpected behavior very often caused by physical issues.
Alex
stanti
steveN
Hey Steven, u seem to be on the right track here..
I reset the LACP counters for po10 and po20 which are the LACP channels back to node A and node B of our SAN.
NEX1# sh lacp counters interface port-channel 10
                    LACPDUs         Marker      Marker Response    LACPDUs
Port              Sent   Recv     Sent   Recv     Sent   Recv      Pkts Err
port-channel10
Ethernet1/3        6      0        0      0        0      0        0
and then PO 20 looks good
NEX1# sh lacp counters interface port-channel 20
port-channel20
Ethernet1/5        2      2        0      0        0      0        0
I'll fire this off the the storage guys as I know this was working.
Thanks for your help on this..
Cheers
Dave
Yes lacp counters is a great command to check if LACP is working or not. However, is there a possibility one end was configured as mode active and other end as mode on?
