07-01-2009 07:14 AM
The latest cli guide on Cisco's website
Cisco MDS 9000 Family
CLI Configuration Guide, Release 3.x
Cisco MDS SAN-OS for Release 3.0(1) Through 3.3(2)
December 2008
says this command should work (page 20-7)
no vsan xxxx interface fc1/3
but I'm getting this
c9216wbtest1(config-vsan-db)# no vsan 1000 interface fc1/3
'no' option is not supported with this command
We're running 3.3.(1c) on this switch. Any thoughts? Am I missing something here?
Solved! Go to Solution.
07-01-2009 07:59 AM
Not sure why the manual states that...but as far as I know, you can not remove an interface from a VSAN. You can move it to another VSAN, but since every port has to be in a VSAN, there is no support for the 'no vsan' command. If you delete a VSAN that has interfaces in it, the ports are mapped to VSAN 4094 (I believe) which is the 'isolated VSAN'. That VSAN can not be used for any traffic, it's landing place for interfaces that have the VSAN deleted out from under them.
I will look into filing a documentation correction as I believe that it is in error.
Hope this helps,
Mike
07-01-2009 07:59 AM
Hope this helps,
Mike
07-01-2009 08:25 AM
Mike,
yeah it didn't make sense so then I wanted to know why my stuff wasn't working if the book says it should.
07-01-2009 10:25 PM
Thanks for identifying the hole the documentation...I will make sure it's corrected in future revisions.
Mike
07-06-2009 11:17 AM
I have filed the feedback to get this corrected in the future versions of the manual. It was also incorrect in the 4.1 version of the manual, on the same page.
Mike
