07-16-2007 11:20 PM
I have inherited a couple of MDS 9509's and as part of my audit I have found Presistent and non-Presistent FCID's. I know if "not used" is selected they will be lost if the switch reboots.
My question is, why would anybody have set non-presistent FCID's?
Hosts are Windows & ESX servers with EVA's.
Thanks.
Solved! Go to Solution.
07-16-2007 11:39 PM
Howdy,
You only really need them if you use AIX and HP-UX.
Pre SanOS 2.0 it was default to NOT have persistent FCID's. Post SanOS 2.0 it is the default to have persistent FCID's.
Cheers
Andrew
07-16-2007 11:39 PM
Howdy,
Cheers
Andrew
