Problem with NT Driver?
I test the storage solution with a SN5438 switch. The switch is running last version 2.5.1-K9 The SN5428 is directly connected to an Hitachi
I have an NT server with service pack6a and driver 2.1.2
Actually the SN5438 could find the disk :
[SN5428]$ sh dev
Fabric Attached Devices detected
Interface WWPN PortId Device Type Lun Lunid Type Luni
d
fc1 500060e802c5a917 0x10100 Disk 0 MD5 4482
94dd25e058fe00022377216fcb02
fc1 500060e802c5a917 0x10100 Disk 1 MD5 70df
19fae061c1eac5167e8b78df6444
Lun Description Table
Interface WWPN Lun Capacity Vendor Product Serial
fc1 500060e802c5a917 0 6GB HITACHI OPEN-9 50601
fc1 500060e802c5a917 1 6GB HITACHI OPEN-9 50601
The NT server is connected to the Sn5428 (all status OK)
[SN5428]$ sh scsi sn5428 host
router host name logins active last login last disconnect
SN5428 193.73.72.71 C930GL1 1 1 Dec 11 10:18:36
But I am unable to find the disk on the NT server. Someone could help me ?
SN5428 connection 193.73.72.71:1026 stats:
RECEIVE SEND
OK ERROR
0000001818 0000001818 total msgs
0000000000 0000000000 no-op msgs
0000000000 0000000000 ping msgs/rsps
0000000000 0000000000 0000000000 SCSI cmd msgs/rsps
0000000000 0000000000 0000000000 SCSI data msgs
0000000000 0000000000 0000000000 task mgt msgs/rsps
0000000002 0000000000 0000000002 login msgs/rsps
0000001816 0000000000 0000001816 text msgs/rsps
0000000000 0000000000 invalid msgs/rsps
0000000000 RTT msgs
0000000000 async msgs
bytes rcvd 0000000000000000
discarded 00000000
bytes sent 0000000000000000
1 connection listed
SN5428 host 193.73.72.71 alias "C930GL1"
Login info:
loginsActive = 1
lastLoginTime: Wed Dec 11 10:18:36 GMT+1 2002
loginsTerminated = 0
lastLoginTerminatedTime:
loginsFailed = 0
lastLoginFailedTime:
loginsDiscovery = 1
loginsNormal = 0
stats:
RECEIVE SEND
OK ERROR
0000001860 0000001860 total msgs
0000001858 0000000000 0000001858 text msgs/rsps
0000000000 RTT msgs
discarded 00000000
1 host listed
SN5428 target Hitachi:
RECEIVED TRANSMITTED
count error count error
0000000000 0000000000 Messages
0000000000 0000000000 0000000000 0000000000 SCSI cmd/resp
0000000000 0000000000 0000000000 login cmd
0000000000 logout
0000000000 async event
0000000000 0000000000 data msg
0000000000000000 bytes received
00000000 discarded
0000000000000000 bytes transmitted
totals for all targets:
0000000000 logout
00000000 discarded
Re: Problem with NT Driver?
It seem that my iscsi driver is in LOGIN status. It should be in ACTIVE status. I dont find what is wrong with my configuration. I tried lots of different TARGET (by LUN, WWPN,..) but it doesnot change anything because the driver could not established.
Thanks to help me.
Jean-Luc Gugler
Jean-Luc,
Could you check that the access list for your target is configured to allow access by your host? You could set it to "any" to make sure.
Chuck
thanks you for your answer. I redo all configuration with command line instead of Browser and finaly I undertood the ACL configuration.
It was effectively the ACL to change. With the storage, putting ACL to "none" mean no access !!!!
Thank you
Jean-Luc
252
