01-26-2012 09:00 AM
I am wondering if you want to do routing on a 5000, has it to be an add-on card? if it is, is it available?
thanks,
Han
Solved! Go to Solution.
01-26-2012 10:25 AM
Nexus 5000 is pure layer 2 switch. You cannot do any type of IP routing with 5010 and 5020s.
Nexus 5500 like 5548 and 5596 can do routing with a daughter card and proper license on it. for 5548 there is a daughter card within a switch and for 5596 there is a L3 module available.
Parts ordering info
N55-D160L3(=)
Nexus 5548 Layer 3 Daughter Card
N55-D160L3-V2(=)
Nexus 5548 Layer 3 Daughter Card, version 2
N55-M160L3(=)
Nexus 5596 Layer 3 Expansion Module
N55-M160L3-V2(=)
Nexus 5596 Layer 3 Expansion Module, version 2
01-26-2012 11:48 AM
Hi.
That's correct - L3 modulte is required for routing protocols and other L3 oprations (HSRP).
Only 55XX series have slot for installing it.
Also you will need following license:
LAN_BASE_SERVICES_PKG
Without it L3 module won't be functional.
This license is free and never expires.
HTH,
Alex
01-26-2012 10:25 AM
Parts ordering info
N55-D160L3(=)
N55-D160L3-V2(=)
N55-M160L3(=)
N55-M160L3-V2(=)
01-26-2012 11:48 AM
Hi.
HTH,
Alex
