Community Member
Setting interop mode 3 to connecnt to Brocade
I need to know which MDS native features are lost after setting interop mode 3.
I'd appreciate to have a document describing this.
Igor
1 REPLY
Re: Setting interop mode 3 to connecnt to Brocade
There is a Switch to Switch Interop Guide on CCO specific to interop 3 is at
http://www.cisco.com/en/US/docs/storage/san_switches/mds9000/interoperability/guide/ICG_im3.html
The only MDS feature I know of that you loose is
Enhanced Zoning on the Inteorp VSAN. Any native MDS VSANs in the same switch would not be impacted. You can trunk the Inteorp VSAN across a port-channel to other MDS. There is no trunking to/from the Brocade though.
Hope this helps,
Mike
431
