Storage Networking
Hi.We have 9336C-FX2 and i trying to configure it for SMB-Direct RDMA using PFC. If i globally enable PFC watch-dog forced, Queue goes to state Shutdown even if watchdog is off traffic won't goes. Howewer on old 9396PX with N9K-M12PQ module everys fi...
KLon by Level 1
  • 124 Views
  • 0 replies
Hi all, first time poster here looking for some direction on a config.We upgraded a 9148S from 8.3(2a) to 9.3(2) - latest supported version and after the upgrade I noticed a few ports that before had the Trunk On.fc1/1 is upPort description is client...
admindude by Level 1
  • 560 Views
  • 2 replies
Hi all, My customer is merging Fabrics and i can see default  VSAN 1 left without any ports. i would like to suspend all VSAN 1 in all fabrics as unless i need to get them unique Domain IDs or VSAN1 stays segmented right in case if there are any conf...
Hello there,i am planning to use the "Image Managment" feature to update MDS 9148s switches. When i try to stage the files the systems says that i dont have enougth space on the bootflash indicated by the red numberWhen i run the staging process it f...
noc_0-1706276937515.png noc_1-1706276986417.png noc_2-1706277059185.png noc_3-1706277244732.png
noc by Level 1
  • 161 Views
  • 0 replies
Hy! I have Cisco SAN switch (DS-C9132T-K9). I created some zone for the standalone servers and storage. And also create zones for my blade and storage. I have 3 blade server: ESX1 pwwn: 50:01:43:80:02:a4:90:00 ESX2 pwwn: 50:01:43:80:02:a4:90:04 ESX3 ...
