TACACS+ and Cisco MDS Switches
I am trying to configure Cisco ACS 4.0 to authenticate Windows domain users who access Cisco MDS Switches but can't seem to get it work. Moreover, the users in Cisco ACS internal database also are not able to login to Cisco switches. Log file says that keys does not match and I have specified the same key in both the places.
Anyboday has any clues as to what could resolve this issue?
Re: TACACS+ and Cisco MDS Switches
Yes, you need a different AV pair. The IOS uses enable levels like enable 15 or enable 10 and that has associated commands with them. The MDS does a role based authentication. So, your AV pair should look like this in the shell portion of the user for MDS's:
cisco-av-pair*shell:roles="network-admin"
Initially I used
cisco-av-pair=shell:roles="network-admin"....it did not work. Then I tried the one you specified...
even this also did not work. Spoke with couple of guys from Cisco and had them take a look at it. They said config looks fine but still can't get it work.
This is what I specified on the Cisco MDS switch.
config t
tacacs+ enable
tacacs-server host xx.xx.xx.xx key wareagle
aaa group server tacacs+ sanmgmtgrp
server xx.xx.xx.xx
aaa authentication login default group sanmgmtgrp
aaa authentication login console local
aaa accounting default group sanmgmtgrp local
end
291
