Trunk configuration error
Hi all,
I have created two port-channel trunk links be a MDS9124 and two separate MDS 9124e's. The trunks work, but in Fabric Manager I see three trunks. The other trunk seen in the list is ports that belong to the first port-channel. What am I doing wrong?
Here are the parts of the config of all three switches. The problem is with MDS9124 and MDS9124e-01
switchname MDS9124
interface port-channel 1
switchport description Port-Channel 1 ISL-Trunk to MDS9124e-1 Port-Channel 1
switchport mode E
no shutdown
interface port-channel 2
switchport description Port-Channel 2 ISL-Trunk to MDS9124e-2 Port-Channel 2
switchport mode E
no shutdown
interface fc1/13
switchport mode E
interface fc1/14
switchport mode E
interface fc1/15
switchport mode E
interface fc1/16
switchport mode E
interface fc1/13
switchport description PortGp=1 Member=1 Trunk link to MDS9124e-ext1
switchport trunk mode on
port-license acquire
channel-group 1 force
no shutdown
interface fc1/14
switchport description PortGp=2 Member=1 Trunk link to MDS9124e-ext1
channel-group 2 force
no shutdown
interface fc1/15
switchport description PortGp=1 Member=2 Trunk link to MDS9124e-ext2
no shutdown
interface fc1/16
switchport description PortGp=2 Member=2 Trunk link to MDS9124e-ext2
no shutdown
switchname SQE-MDS9124E-01
switchport description Port-Channel 1 ISL-Trunk to MDS9124 Port-Channel 1
switchport mode E
no shutdown
interface ext1
switchport mode E
interface ext2
switchport mode E
interface ext1
switchport description PortGp=1 Member=1 Trunk link to MDS9124-Port13
no shutdown
interface ext2
switchport description PortGp=1 Member=2 Trunk link to MDS9124-Port15
no shutdown
switchname SQE-MDS9124E-02
switchport description Port-Channel 2 ISL-Trunk to MDS9124 Port-Channel 2
switchport mode E
no shutdown
interface ext1
switchport mode E
interface ext2
switchport mode E
interface ext1
switchport description PortGp=2 Member=1 Trunk link to MDS9124-Port14
no shutdown
interface ext2
switchport description PortGp=2 Member=2 Trunk link to MDS9124-Port16
no shutdown
Thanks for your time and help,
Nick
Re: Trunk configuration error
Nick,
I'm a bit confused. The config above looks correct for your 2 port channels. Could it be that you have a cable between the 9124 and 9124e-01 that is not part of the port-channel and what you see in FM is the port-channel and a parallel ISL? If you mouse over the link on the FM map, it should tell you which ports on each end of the link are in which interfaces. If you see the same port-channel 2 times, it might be a display issue with FM.
Also, there is a display option called 'expand links'. If you mouse over the port-channel link onm FM and click on this, it will not show the port-channel as a single think line, but rather 1 thin line for each link in the port channel. In your example, it would show the port-channel as 2 thin lines, while on the other port-channel, if this option is not in use, that one will appear as a single thick line.
From the CLI there is also a 'show topology' command that I believe will show you what ports on the local switch are attached to what ports on the remote switch.
Hope this helps,
Mike
Thanks Mike,
I got pulled off this proble until now. I hear what your are saying. But that is the problem. I see the port channel link with both port as member, then I see another link (parallel) are next to in. But this other link is a member of port-channel. I don't know how to clear this issue.
Nick
I attached a pic of what FM is showing me. You can see the on the top the three links, the first one is my problem. Also, there are only the two ports cabled bewteen the main switch and the two different 9124e's
166
