unify Fc interface on 5548UP down
hello,
I try to configure FC on a cisco 5548. I change last interface on the switch in native FC with SFP FC 8G SW an LW. We manage a new vlan associate with a vsan 806
Interface are down with error npmExtLinkDown and I can't find any information about this status.
`show interface brief`
Interface  Vsan   Admin  Admin   Status          SFP    Oper  Oper   Port
                  Mode   Trunk                          Mode  Speed  Channel
                         Mode                                 (Gbps)
fc1/23     1      F      off     sfpAbsent        --     --           --
fc1/24     1      F      off     sfpAbsent        --     --           --
fc1/25     1      F      off     sfpAbsent        --     --           --
fc1/26     1      F      off     sfpAbsent        --     --           --
fc1/27     806    F      off     npmExtLinkDown   swl    --           --
fc1/28     806    F      off     npmExtLinkDown   swl    --           --
fc1/29     806    F      off     sfpAbsent        --     --           --
fc1/30     806    NP     off     notConnected     lwcr   --           --
fc1/31     806    F      off     sfpAbsent        --     --           --
fc1/32     806    F      off     sfpAbsent        --     --           --
Ethernet      VLAN    Type Mode   Status  Reason                   Speed     Port
Interface        Ch #
Eth1/1        1       eth  trunk  up      none                        10G(D) 100
Eth1/2        1       eth  trunk  down    SFP not inserted            10G(D) 100
Eth1/3        1       eth  trunk  up      none                        10G(D) --
Eth1/4        1       eth  trunk  down    SFP not inserted            10G(D) --
Eth1/5        1       eth  access down    SFP not inserted            10G(D) --
Eth1/6        1       eth  access down    SFP not inserted            10G(D) --
Eth1/7        1       eth  access down    SFP not inserted            10G(D) --
Eth1/8        1       eth  access down    SFP not inserted            10G(D) --
Eth1/9        1       eth  access down    SFP not inserted            10G(D) --
Eth1/10       1       eth  access down    SFP not inserted            10G(D) --
Eth1/11       1       eth  access down    SFP not inserted            10G(D) --
Eth1/12       1       eth  access down    SFP not inserted            10G(D) --
Eth1/13       1       eth  access down    Link not connected          10G(D) --
Eth1/14       1       eth  access down    Link not connected          10G(D) --
Eth1/15       1       eth  access down    SFP not inserted            10G(D) --
Eth1/16       1       eth  access up      none                        10G(D) --
Eth1/17       1       eth  access down    SFP not inserted            10G(D) --
Eth1/18       1       eth  access down    SFP not inserted            10G(D) --
Eth1/19       1       eth  trunk  up      none                        10G(D) --
Eth1/20       1       eth  access down    SFP not inserted            10G(D) --
Eth1/21       1       eth  access down    SFP not inserted            10G(D) --
Eth1/22       1       eth  access down    SFP not inserted            10G(D) --
also my vsan is down
`show vsan`
vsan 1 information
name:VSAN0001  state:active
interoperability mode:default
loadbalancing:src-id/dst-id/oxid
operational state:down
vsan 806 information
name:VSAN0806  state:active
vsan 4079:evfp_isolated_vsan
vsan 4094:isolated_vsan
`show vsan membership`
vsan 1 interfaces:
    fc1/23            fc1/24            fc1/25            fc1/26
vsan 806 interfaces:
    fc1/27            fc1/28            fc1/29            fc1/30
    fc1/31            fc1/32
vsan 4079(evfp_isolated_vsan) interfaces:
vsan 4094(isolated_vsan) interfaces:
here is my config file
`show running-config`
!Command: show running-config
!Time: Sun Mar  8 22:41:32 2009
version 6.0(2)N2(1)
feature fcoe
hostname SW5548UP-CL1-R-1
feature telnet
cfs ipv4 distribute
cfs eth distribute
feature interface-vlan
feature lacp
feature vpc
feature lldp
username admin password 5 /*******************/ role network-admin
no password strength-check
ip domain-lookup
system qos
  service-policy type queuing input fcoe-default-in-policy
  service-policy type queuing output fcoe-default-out-policy
  service-policy type qos input fcoe-default-in-policy
  service-policy type network-qos fcoe-default-nq-policy
control-plane
  service-policy input copp-system-policy-customized
slot 1
  port 23-32 type fc
vrf context management
vlan 1
vlan 806
  fcoe vsan 806
  name FCoE-Bas
vpc domain 1
  peer-keepalive destination 10.*.*.*
port-profile default max-ports 512
vsan database
  vsan 806
interface Vlan1
interface Vlan888
  description interface management inband
  no shutdown
  ip address 10.222.50.242/24
interface port-channel100
  switchport mode trunk
  switchport trunk allowed vlan 1-804,807-4094
  spanning-tree port type network
  speed 10000
  vpc peer-link
vsan database
  vsan 806 interface fc1/27
  vsan 806 interface fc1/28
  vsan 806 interface fc1/29
  vsan 806 interface fc1/30
  vsan 806 interface fc1/31
  vsan 806 interface fc1/32
feature npv
interface fc1/23
interface fc1/24
interface fc1/25
interface fc1/26
interface fc1/27
  no shutdown
interface fc1/28
  no shutdown
interface fc1/29
interface fc1/30
  switchport description vers SW5548UP-CA3-R-1 Fc1/30 lien fc01
  no shutdown
interface fc1/31
  switchport description vers metro nseries FC
interface fc1/32
  switchport description vers ESX-DMZB
interface Ethernet1/1
  description vers vers SW5548UP-CL1-R-2 Et1/1
  channel-group 100 mode active
interface Ethernet1/2
  description vers vers SW5548UP-CL1-R-2 Et1/2
interface Ethernet1/3
  description vers SW3750X-CL1-R-1 Te1/0/2
  switchport trunk allowed vlan 888
interface Ethernet1/4
  description vers RTR3800X-CL1-R-1 Ten0/1
  switchport trunk allowed vlan 6-8,10,12-17,100,150,160-166,200-203,230,450,700-704,710,888
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet1/10
interface Ethernet1/11
interface Ethernet1/12
interface Ethernet1/13
  description vers SW4001I-CL1-DC-1 chemin bas
interface Ethernet1/14
interface Ethernet1/15
interface Ethernet1/16
interface Ethernet1/17
interface Ethernet1/18
interface Ethernet1/19
  description vers SW5548UP-CA3-R-1 Et1/19
  switchport trunk allowed vlan 6-8,10,12-17,100,150,160-166,200-203,206,230
interface Ethernet1/20
interface Ethernet1/21
interface Ethernet1/22
interface mgmt0
  vrf member management
  ip address 10.200.1.242/24
line console
line vty
boot kickstart bootflash:/n5000-uk9-kickstart.6.0.2.N2.1.bin
boot system bootflash:/n5000-uk9.6.0.2.N2.1.bin
ip route 0.0.0.0/0 10.222.50.254
interface fc1/27
  switchport speed 4000
interface fc1/23
  switchport mode F
interface fc1/24
  switchport mode F
interface fc1/25
  switchport mode F
interface fc1/26
  switchport mode F
interface fc1/27
  switchport mode F
interface fc1/28
  switchport mode F
interface fc1/29
  switchport mode F
interface fc1/30
  switchport mode NP
interface fc1/31
  switchport mode F
interface fc1/32
  switchport mode F
how can i start vsan and my FC interface
I would like to do native FC with zonings zoneset, fcal, ... I can't use show flogi database, what feature do i missing ?
thank's a lot for your help.
1 ACCEPTED SOLUTION
                         Mode                                 (Gbps)
Running config has
feature npv
In NPV mode, this switch cannot relay a flogi to the upstream NPIV switch unless the NP interface is up.
Do you intend to connect fc1/30 to an NPIV switch?
Options:
connect this switch to an NPIV enabled switch.
or
Take this switch out of NPV mode
   no feature npv
   copy run start
   reload
The flogi database will be on the NPIV switch,
you can use, "show npv flogi" on the NPV switch.
David
                         Mode                                 (Gbps)
Running config has
feature npv
Options:
or
   no feature npv
   copy run start
   reload
David
Ok I have transform this configuration without NPV feature.
Interface came's up and I find my wwn on the flogi database to make zoning.
this nexus is interconnect to an another N5K where I also use Npiv. I think that I will transforme also it in "Full fabric" without npiv but for my education I have the following error :
the interface NP "uplink" is in init mode in other side interface is in up and F mode with a WWN
full fabric side
                         Mode                                 (Gbps)
fc1/23     1      F      on      sfpAbsent        --     --           --
fc1/24     1      F      on      sfpAbsent        --     --           --
fc1/25     1      F      on      sfpAbsent        --     --           --
fc1/26     1      F      on      sfpAbsent        --     --           --
fc1/27     806    F      on      up               swl    F       4    --
fc1/28     806    F      on      up               swl    F       4    --
fc1/29     806    F      on      sfpAbsent        --     --           --
fc1/30     806    F      on      up               lwcr   F       8    --
fc1/31     806    F      on      down             swl    --           --
fc1/32     806    F      on      down             swl    --           --
NPIV side
                         Mode                                 (Gbps)
fc1/30     806    NP     off     init             lwcr   --           --
fc1/31     806    F      off     npmExtLinkDown   swl    --           --
fc1/32     806    F      off     npmExtLinkDown   swl    --           --
config from NPIV side
version 5.2(1)N1(3)
feature fcoe
logging level feature-mgr 0
hostname SW5548UP-CA3-R-1
feature telnet
cfs ipv4 distribute
feature lldp
slot 1
  port 27-32 type fc
vlan 806
  fcoe vsan 806
  name FCoE-Bas
vsan database
  vsan 806
interface vfc8
  bind mac-address 00:c0:dd:21:82:43
  switchport description Emplacement 8 Blade 1 CAPS - THEMIS
  switchport trunk mode on
  no shutdown
interface vfc10
  bind interface Ethernet1/29
  switchport description temp dmz
  no shutdown
interface vfc30
interface vfc31
interface vfc32
interface vfc110
  bind mac-address 00:c0:dd:26:0c:8f
  no shutdown
interface vfc112
  bind mac-address 00:c0:dd:21:82:b3
  no shutdown
interface vfc113
  bind mac-address 00:c0:dd:21:81:6b
  no shutdown
vsan database
  vsan 806 interface vfc8
  vsan 806 interface vfc10
  vsan 806 interface vfc110
  vsan 806 interface vfc112
  vsan 806 interface vfc113
feature npv
feature npiv
npv traffic-map server-interface fc1/32 external-interface fc1/30
npv traffic-map server-interface vfc8 external-interface fc1/30
npv traffic-map server-interface vfc10 external-interface fc1/30
npv traffic-map server-interface vfc110 external-interface fc1/30
npv traffic-map server-interface vfc112 external-interface fc1/30
npv traffic-map server-interface vfc113 external-interface fc1/30
interface fc1/30
  switchport description vers int 15 brocade bas
  no shutdown
interface fc1/31
  switchport description vers Metrocluster FC
  no shutdown
interface fc1/32
  switchport description SERVEUR DMZ
  no shutdown
Thank's a lot for your help
IS this the topology?
NPV                         NPIV
N5K fc1/30 init - up fc1/30 N5K
Maybe the interfaces are flapping?
If you shut the interfaces on one end of the link, does the interface at the other of the link go down?
The fc1/30 descripiton says brocade.
Is there more information in both switches with the command,
  show interface fc1/30
   show logging log
Does the pwwn in the flogi database match the wwn in show interface on the NPV switch?
We change our topology without Npiv or npv. "full fabric"
so this is our topology objective :
we have emplemented server on site x with blade and cisco 4005i with fip snooping. we created vfc on nexus 5K zoning. we have normal wwn on the flogi database and show zone active show fcid.
we make zoning to communicate with the DS4700 target on site y and with the n metro from site x. metro on site x and the ds4700 can't see any wwn initiator from the CNA interface and we can't see san target from the CNA bios gui.
a server with normal FC interface on fc1/32 work and can communicate with ds4700 and nserie without any issue has usual.
here is config from n4K
version 4.1(2)E1(1j)
feature telnet
feature tacacs+
feature fip-snooping
vlan 806
  fip-snooping enable
  fip-snooping fc-map 0x0efc00
  name FCoE-BAS
interface port-channel15
  description vers n5K
  fip-snooping port-mode fcf
  speed 10000
  spanning-tree port type edge trunk
  speed auto
  speed auto
  speed auto
  speed auto
  description vers SW5548UP-CA3-R-1 eth 1/13 dans Po15
  speed 10000
  channel-group 15
  description vers SW5548UP-CA3-R-1 eth 1/14 dans Po15
  speed 10000
  channel-group 15
nexus site X
version 6.0(2)N2(1)
feature fcoe
feature telnet
cfs ipv4 distribute
feature lldp
vlan 806
  fcoe vsan 806
  name FCoE-Bas
vsan database
  vsan 806
fcdomain fcid database
  vsan 806 wwn 50:0a:09:84:9d:e2:5c:61 fcid 0x560000 dynamic
  vsan 806 wwn 21:00:00:1b:32:8a:ac:59 fcid 0x560100 area dynamic
  vsan 806 wwn 21:00:00:c0:dd:26:0c:8f fcid 0x560040 dynamic
  vsan 806 wwn 21:00:00:c0:dd:21:82:b3 fcid 0x560060 dynamic
  vsan 806 wwn 21:00:00:c0:dd:21:81:6b fcid 0x560080 dynamic
interface vfc101
  switchport description ESXi-E
  no shutdown
interface vfc102
  switchport description ESXi-D
  no shutdown
interface vfc103
  switchport description ESXi-A
  no shutdown
vsan database
  vsan 806 interface vfc30
  vsan 806 interface vfc101
  vsan 806 interface vfc102
  vsan 806 interface vfc103
interface fc1/30
  switchport description vers SW5548UP site y
  no shutdown
interface fc1/31
  no shutdown
interface fc1/32
  no shutdown
and nexus 5k site Y with the zoneset
version 6.0(2)N2(1)
feature fcoe
feature telnet
cfs ipv4 distribute
cfs eth distribute
feature lacp
feature vpc
feature lldp
vlan 806
  fcoe vsan 806
  name FCoE-Bas
vsan database
  vsan 806
  vsan 806 wwn 20:44:00:a0:b8:32:0c:dc fcid 0x400000 area dynamic
  vsan 806 wwn 20:35:00:a0:b8:32:0c:dc fcid 0x400100 area dynamic
  vsan 806 wwn 20:1e:54:7f:ee:ae:9d:80 fcid 0x400200 dynamic
vsan database
!Full Zone Database Section for vsan 806
fcalias name DS4700CA vsan 806
    member pwwn 20:44:00:a0:b8:32:0c:dc
fcalias name DS4700CB vsan 806
    member pwwn 20:35:00:a0:b8:32:0c:dc
fcalias name esxdmza vsan 806
    member pwwn 21:00:00:1b:32:8a:ac:59
fcalias name nCaps vsan 806
    member pwwn 50:0a:09:84:9d:e2:5c:61
fcalias name ESXi-E vsan 806
    member pwwn 21:00:00:c0:dd:21:81:6b
fcalias name ESXi-A vsan 806
    member pwwn 21:00:00:c0:dd:21:82:b3
fcalias name ESXi-D vsan 806
    member pwwn 21:00:00:c0:dd:26:0c:8f
zone name esxdmza_DS4700CA vsan 806
    member fcalias DS4700CA
    member fcalias esxdmza
zone name esxdmza_DS4700CB vsan 806
    member fcalias DS4700CB
zone name ESXi-E_DS4700CA vsan 806
    member fcalias ESXi-E
zone name ESXi-E_DS4700CB vsan 806
zone name ESXi-E_nCaps vsan 806
    member fcalias nCaps
zone name esxdmza_nCaps vsan 806
zone name ESXi-A_DS4700CA vsan 806
    member fcalias ESXi-A
zone name ESXi-A_DS4700CB vsan 806
zone name ESXi-D_DS4700CB vsan 806
    member fcalias ESXi-D
zone name ESXi-D_DS4700CA vsan 806
zoneset name FCoE-Bas vsan 806
    member esxdmza_DS4700CA
    member esxdmza_DS4700CB
    member ESXi-E_DS4700CA
    member ESXi-E_DS4700CB
    member ESXi-E_nCaps
    member esxdmza_nCaps
    member ESXi-A_DS4700CA
    member ESXi-A_DS4700CB
    member ESXi-D_DS4700CB
    member ESXi-D_DS4700CA
zoneset activate name FCoE-Bas vsan 806
zoneset look like nice
`show zoneset active vsan 1-4093`
  * fcid 0x400000 [pwwn 20:44:00:a0:b8:32:0c:dc]
  * fcid 0x560100 [pwwn 21:00:00:1b:32:8a:ac:59]
  * fcid 0x400100 [pwwn 20:35:00:a0:b8:32:0c:dc]
  * fcid 0x560080 [pwwn 21:00:00:c0:dd:21:81:6b]
  * fcid 0x560000 [pwwn 50:0a:09:84:9d:e2:5c:61]
  * fcid 0x560060 [pwwn 21:00:00:c0:dd:21:82:b3]
  * fcid 0x560040 [pwwn 21:00:00:c0:dd:26:0c:8f]
for your Information,
Mistake came from a global Qos configuration who break the auto process who create a mandatory QOS for FCoE. so we built a qos who can transport FCoE and is now working.
1151
