Community Member
With or Without San-Port-Channel
Hello
I have a small SAN Fabric composed of 2 NX5596 adn on NX5548 configured with FC Swiching.Fabric_SWSANUNIDCT02.jpg
Each Switch is connected with a pair of 2 FC 8Gbps with each other Switch configured as ISL Trunk.
Without San-Port-Channel configured configured everything is working fine, also in the case where only one link between 2 Switches FC is going down.
This failure is e.g. fully transparent with IOMETER and File Explorer.
Instead as I aggregate the pair of ISL Link bwetween 2 Swithces FC within a San-Port-Channel, a failure of Link in the channel issue a timeout with IOMETER for approx. 30-55 secondes and the File explorer may be (Not responding) for a few secondes.
I did the tests with and without IOD, but with almost the same result.
I also did the test with 2 LoadBalancing Type : srcId/DestId/OxId and srcId/DestID and also with almost the same result.
I always though the configuration WITH San-Port-Channel would have better behavior in failure condition as a configuration WITHOUT San-Port-Channel.
Is there something specific to configure within the San-Port-Channel to improve its performance?
Kind regards
Jean-Marc
373
