CISCO AIR-AP1242AG-E-K9 HELP
Xmodem file system is available.
flashfs[0]: 9 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 3475968
flashfs[0]: Bytes available: 12523008
flashfs[0]: flashfs fsck took 26 seconds.
Base ethernet MAC Address: 00:19:55:73:67:bc
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
button pressed for 20 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
image_recovery: Download default IOS tar image tftp://255.255.255.255/c1240-k9w7-tar.default
examining image...tftp://255.255.255.255/c1240-k9w7-tar.default: connection timed out
ERROR: Failed to open archive file tftp://255.255.255.255/c1240-k9w7-tar.default
Loading "flash:/c1240-rcvk9w8-mx.124-25e.JAP10/c1240-rcvk9w8-mx.124-25e.JAP10"...#####################################################################################################################################################################################################################################################################
File "flash:/c1240-rcvk9w8-mx.124-25e.JAP10/c1240-rcvk9w8-mx.124-25e.JAP10" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1240 Software (C1240-RCVK9W8-M), Version 12.4(25e)JAP10, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 22-Aug-16 23:45 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 8 files, 2 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15740928
flashfs[1]: Bytes used: 3475968
flashfs[1]: Bytes available: 12264960
flashfs[1]: flashfs fsck took 3 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
agree tcomply with applicable laws and regulations. If you are unable
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
%Error opening flash:/c1240-rcvk9w8-mx/info (No such file or directory)cisco AIR-AP1242AG-E-K9 (PowerPCElvis) processor (revision A0) with 27638K/5120K bytes of memory.
Processor board ID FCZ103880RC
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 8.0.110.7
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:19:55:73:67:BC
Part Number                          : 73-10256-05
PCA Assembly Number                  : 800-26918-04
PCA Revision Number                  : B0
PCB Serial Number                    : FOC10361LS0
Top Assembly Part Number             : 800-26965-03
Top Assembly Serial Number           : FCZ103880RC
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1242AG-E-K9
% Please define a domain-name first.
logging facility kern
% Invalid input detected at '^' marker.
logging trap emergencies
Press RETURN to get started!
*Mar  1 00:00:05.049: %LWAPP-4-CLIENTEVENTLOG: Unable to open event log file flash:/event.log
*Mar  1 00:00:05.050: %LWAPP-4-CLIENTEVENTLOG: Read and initialized AP event log (contains, 0 messages)
*Mar  1 00:00:05.051: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:07.213: %LINK-6-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:07.241: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:07.338: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:07.339: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default configlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:07.900: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power source
*Mar  1 00:00:08.213: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 00:00:16.741: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 192.168.1.248, mask 255.255.255.0, hostname AP0019.5573.67bc
Translating "CISCO-CAPWAP-CONTROLLER.ASUS"...domain server (192.168.1.1)
Translating "CISCO-LWAPP-CONTROLLER.ASUS"...domain server (192.168.1.1)
*Mar  1 00:00:37.107: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:00:37.133: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.ASUS
*Mar  1 00:00:37.147: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER.ASUS
Not in Bound state.
*Mar  1 00:01:32.655: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:01:35.673: %CAPWAP-3-ERRORLOG: Invalid event 38 & s
*Mar  1 00:01:35.782: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 192.168.1.248, mask 255.255.255.0, hostname AP0019.5573.67bc
*Mar  1 00:01:43.656: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:01:43.692: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.ASUS
*Mar  1 00:01:43.714: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER.ASUS
  • Support Community Help
Everyone's tags (1)
26
