06-02-2016 07:22 AM - last edited on 07-27-2018 09:53 AM by Cheri Fairbrother
Hello
Present the following problem, Generate an entitlement file may not believe and tells me the following message "Entitlement file generation failed. Please try again. If the issue Persists, find help in the community", need help and if possible I indicated as solve this problem.
Regards.-
06-07-2016 07:00 AM
Our back-end team is investigating the issue. We will provide an update as soon as it becomes available.
Thank you.
06-07-2016 09:46 PM
Hello Aldo ,
Thanks for reaching out to us.
I see that you have already registered 2 CSPC ID's for the account , So Could you please send us the screen shot from the first step without hiding any data from the SNTC portal UI to sntc-support-community@cisco.com only if the issue still persists .
Pamela
06-10-2016 12:15 PM
06-14-2016 09:18 AM
Hi Aldo,
Could you please follow the below steps and try one more time :
1) Log off from portal UI.
2) Clear browser history /cache .
3) Close the browser .
4) Log in again to the portal UI.
5) Then try to generate certificate .
6) Keep us posted if still see the issue.
In general we don’t have any reported issue related to portal certificate generation issue.
