SG200-50 LACP on port 49 and 50
DSI DSI
Hello
I used LACP on port 49 and 50.
After upgrade firmware from 1.0.0.19 to 1.1.2.0 my LAG1 stay down...all port member stay down, port link is up but LAG stay down...
I testtu delete and reconfigure LAG1 but nothing work...
rmanthey
Level 4
Level 4
Hello DSI
What is the port 49 and 50 connecting to? What is the configuration on that device?
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
My settings are on SG200-51 Number 1:
Port Management / Port Settings :
Interface  | Port Type            | Status Port | Speed Duplex | Mode | LAG
GE49       | 1000M-ComboC | Up               | 1000M             | Full    | 1
GE50       | 1000M-ComboC | Up               | 1000M             | Full    | 1
In Port Management / Link Aggregation / LAG Management :
LAG   | Name           | LACP      | Link State      | Active member  |  Standby Member
LAG1 | Networks1   | Enabled   | Link Down    |                            | GE49, GE50
In Port Management / Link Aggregation / LAG Settings :
Entry N° |  LAG | Descritpion | type | status | auto négotiontion| speed | flow Control
     1       | LAG1 |Networks1   |         | Down |                            |             |
In Port Management / Link Aggregation / LACP :
Entry No. | Port    | Port Priority | LACP Timeout
    49        |GE49   |1                    |Long
    50        | GE50  |1                    |Long
I have this problème with some SG200.
In case 1 with a other SG200 with the same configuration for LAG
In case 2 wiith Catayst 2960S with LAG configuration.
But before fireware upgrade on SG200 all work fine!
DSI,
I would recommend calling the 1866-606-1866 support number and creating a case, so we can gather further information.
thanks
Randy Manthey
