SRW248G4 uplink via fiber to EF3124
sburleson
I currently have (2) EF3124 uplinked via fiber. Should there be any issues with compatibility if I install a SRW248G4 switch to replace one of the EF3124 switches over fiber? I realize that the SRW248G4 needs its own fiber module but should there be any communication issues since everything is MMF?
wichilds
Level 4
Level 4
Here is a link to the SFP modules. It tells the MMF you will need to use with the SRW switch you are asking about.
https://www.cisco.com/cisco/web/solutions/small_business/products/routers_switches/small_business_network_accessories/index.html-tab-ForPartners
As far as protocol compatibility, there should not be any issues unless you want the switch to do CDP; only Cisco branded equipment is capable/configured for that.
Bill
