Using mini gbic to stack 2 SGE2010`s
nhaydock1
Is there any major advantage of using the GBIC ports for stacking over the regular gb ports (24 and 48 I beleive?) in terms of performance, stability, etc?
Neil
David Hornstein
Level 7
Level 7
Hi Neil,
So to answer the question simply, there is no extra benefit in using mini GBICs (SFP) compared to a CAT6 cable to connect switches together in a stack.  Both copper or fiber connections  will sync at 1000Mb/sec.
The  only benefit of using mini GBICs or SFP;s is if the connection between the switches are beyond 100 meters or 328 feet.
But I am more than happy to connect switches together with CAT6 cables for stacking purposes, it's more cost effective.
regards Dave
David Hornstein
Level 7
Level 7
Hi Neil,
regards Dave
Cheers Dave, much appreciated!
