6509 power supply issue
mhurley131
Level 4
Level 4
I have a 6509 with 2 x WS-CAC-3000W power supplies installed. The issue is that when i do a sh power it shows the PS are only supplying 1200w of power each.
Why would these power supplies not put out their full wattage?
system power redundancy mode = combined
system power total = 1952.16 Watts (46.48 Amps @ 42V)
system power used = 1611.12 Watts (38.36 Amps @ 42V)
system power available = 341.04 Watts ( 8.12 Amps @ 42V)
Power-Capacity PS-Fan Output Oper
PS Type Watts A @42V Status Status State
1 WS-CAC-3000W 1171.38 27.89 OK OK on
2 WS-CAC-3000W 1171.38 27.89 OK OK on
taali
Are you plugged into 110 VAC or 220 VAC?
The 3000W P/S requires 220 V input to deliver 3000W of power. Check out:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Chassis_Installation/Cat6500/0apwsply.html#wp1028905
