7200 VXR router
vaibhav-g
is the nvram in NPE-400 or on the I/O controller in 7200 Vxr router
Giuseppe Larosa
Hello Vaibhav,
if you are planning to upgrade to NPE-G1 or better you need to backup the config file.
see
http://www.cisco.com/en/US/docs/routers/7200/install_and_upgrade/npe-g1_read_me/14025R.html#wp29664
in older processors they look for NVRAM on I/O controllers but NPE-G1 can work without an I/O controller so it has its own NVRAM
So the config file should be on I/O controller with an NPE 400
Hope to help
Giuseppe
