Cat2960G issue
a.sapelnikov
Message
!!! WARNING: The switch is not usable !!!
Unable to create l2trace server process, socket_open() failed
appears during switch loading.
Message:
Unable to open UDP socket on CMP_PORT appears after IOS loading.
Switch does't work.
What should I do?
mihanlin
This message typically means a hardware failure.
If you plug a console into the switch and watch it boot, you should see a particular message indicating POST failure on a specific line, something like this:
POST: PortASIC CAM Subsystem Tests : Begin
TCAM (asic:5) walking-one test failed
Write: 80_00000000_00000000-00_00010000_00000000
Read: 80_00000000_00000000-00_04000000_00000000
POST: POST Failed
POST: PortASIC CAM Subsystem Tests : End, Status Failed
POST: CAM test failed
If this switch is under contract, it should be RMA'd
glen.grant
Call cisco the 2960 has a limited lifetime warranty. If you don't have a contract I think replacement time is like 10 days.
