Cisco 5505 console
I have Cisco Catalyst 5505 Chasis. In first slot I connected ws-x5540 Sup Engine. But when I am starting switch, I am getting only below information.
ATE0
ATS0=1
ROM Power Up Diagnostics of Apr 20 1999
Init NVRAM Log
LED Test ................... done
ROM Checksum ............... passed
Dual Port RAM r/w Test ..... passed
ID PROM .................... passed
System DRAM Size(mb) ....... 32
DRAM Data Bus Test ......... passed
DRAM Address Test .......... passed
DRAM Byte/Word Access Test .. passed
uncompressing nmp image
This will take a minute...
NMP image is successfully uncompressed in DRAM
I am not getting user mode after this.
LED status of system status,fan,power supply,active showing green.
Can u tell me why I am not getting user mode?????
irisrios
Level 6
Level 6
Reload the IOS image and reboot the device to recover the device. Check if the URL http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00800949c3.shtml helps you.
thanks for your reply.
But my problem solved by only cleaning & installing DRAM & Flash properly on sup engine.
