Cisco 6500 redundant supervisor etherchannel
Sudhir Menon
Hello Friends,
I have 2 Cisco 6500 series switch with VS-C6509E-S720-10G ,I have two redundant supervisors in the same chassis on the LAN with no add-on line cards
I need to know if I can use the redundant supervisor 10 Gb uplinks to form a layer-2 Port channel between the two 6500 switches as i do not want to use want to keep the port idle additionally I need more bandwidth between the two switches for my server farm
Thanks in advance ....
Sudhir
2 Accepted Solutions
Hi Sudhir,
You can configure the etherchannel as you mentioned above.
Please rate the helpfull posts.
Naidu.
Correct both are possible as well as On mode on ports from Standby and Active SUPs.
Nik
HTH,
Niko
7 Replies 7
nkarpysh
Hi Sudhir,
Yes you can use those. The active SUP will maintain all control functions but redandant one ports are still operational.
Nik
HTH,
Niko
Hello Nik,
Thanks for replying,
So will the configuration be a normal layer-2 etherchannel configuration with LACP or PAGP or does it require some feature to be enabled
Sudhir
Hi Sudhir,
See the below link will help you.
There is a setup with explaination like VSS.
http://www.netcraftsmen.net/component/content/article/69-data-center/749-vss-configuration.html
Naidu.
Hello Latchum,
Not sure if you really got my question ,here it is
I have 2 supervisors VS-C6509E-S720-10G in one chassis of Catalyst 6509 and I have two chassis ,I just want to utlise the port on the redundant supervisor for my data connection
So it is a normal layer-2 port channel between Chassis-1 Te5/4& Te6/4 and Chassis-2 Te5/4 and Te 6/4
Pls let me know if this is possible , I dont want to configure VSL link nor do i want to use it as VSS
Sudhir
Hi Sudhir,
Naidu.
Nik
HTH,
Niko
Thank you Nik and Latchum to both of you for all your help
