02-22-2010 07:38 PM - edited 03-06-2019 09:50 AM
Hi All
I am trying to configure ssh access to my 4506 switch. Does anyone know which version image supports ssh because my present version does not seem to support it. I cannot get the "sh crypto" or "sh rsa ... " commands going?
Thanks.
THANKSSWITCH#sh ver
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(20)EWA1,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 20-Apr-05 14:35 by ccai
Image text-base: 0x00000000, data-base: 0x01224344
ROM: 12.2(20r)EW1
Dagobah Revision 226, Swamp Revision 34
THANKSSWITCH uptime is 2 years, 32 weeks, 5 days, 16 hours, 56 minutes
System returned to ROM by reload
System restarted at 23:06:07 NZST Mon Jul 9 2007
System image file is "bootflash:"
cisco WS-C4506 (MPC8245) processor (revision 10) with 262144K bytes of memory.
Processor board ID FOX090700Z0
MPC8245 CPU at 266Mhz, Supervisor II+
Last reset from Reload
8 Virtual Ethernet/IEEE 802.3 interface(s)
96 FastEthernet/IEEE 802.3 interface(s)
50 Gigabit Ethernet/IEEE 802.3 interface(s)
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
THANKSSWITCH#sh bootflash
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- n
ame
1 .. image 2D397A09 C24218 30 12468632 Jun 25 2005 07:21:36 +12:00 c
at4000-i9s-mz.122-20.EWA1.bin
14794216 bytes available (12468760 bytes used)
02-22-2010 07:50 PM
Hello Sydney,
To support SSH you need an IOS image with k9 in the name
Here is an example for 4500
cat4500-ipbasek9-mz.122-53.SG1.bin
12.2(53) is the latest on CCO
Reza
02-22-2010 07:53 PM
Reza, thanks Buddy. Much appreciated.
Sydney
02-22-2010 07:54 PM
The current IOS which is running will not support ssh.
you need to upgrade your IOS into
Release Feature Set/License Image Name DRAM Flash
12.2(53)SG1 ENTERPRISE SERVICES SSH cat4500-entservicesk9-mz.122-53.SG1.bin 256 64
Karuppu
