04-19-2012 08:04 AM - edited 03-07-2019 06:13 AM
hi guys,
does anyone knows what other command can be used to debug packets on a 3750 switch ?
I'm used to debug ip packet access-list, bun the command is not supported any more:
The debug ip packet command displays packets received by the switch CPU. It does not display packets that are hardware-switched. (
Thanks. Adrian
04-19-2012 05:12 PM
I personally haven't used this command before, and from what I read it wasn't a supported command on the 3750. Would using the 'monitor session' commands be an option for you along with wireshark or some other capturing program?
04-20-2012 12:11 AM
hi Jason,
That will be a way, but unfortunately the switch where i'm trying this is in a colo and i don't have any servers where to put wireshark.
Thanks. Adrian
