Firmware Upgrade C6504-E
Hi dear Community,
i've a short question.
I'll upgrade our C6504-E L3-Switches , I found few files but which are needed.
c6ksup32-rm2.srec.122-18r.SX9.bin      is installed no issues
c6msfc2a-rm2.srec.122-17r.S6             is installed, no issues
s3223-ipservicesk9_wan-mz.122-33.SXI9.bin      is installed, no issues
But I#ve on idea to this file   s3223-boot-mz.122-33.SXI9.bin
What I've done is:
- copy this file into bootflash:
- and enter bootmaker:  boot bootldr bootflash:s3223-boot-mz.122-33.SXI9.bin
So my config has now this :
boot system flash sup-bootdisk:s3223-ipservicesk9_wan-mz.122-33.SXI9.bin
But I think the bootldr has no effect, Is this bootldr needed with a sup32 ? And is my way the right to put it into the system ?
Kind Reagds
Matthias Martens
Ivan Shirshin
The boot bootldr command sets the BOOTLDR environment variable in the current running configuration and is used on supervisors to download the IOS from the Sup to the MSFC.
The bootloader image is mandatory for MSFC1, and  must be placed in the MSFC bootflash. A bootloader image is not a  requirement for the MSFC2 (and Supervisor engine 32 has MSFC2A onboard). However, Cisco recommends that you use a boot  image as described in procedure. A boot image is a much smaller,  scaled-down version of the system image. With a boot image, you can  perform a TFTP image transfer if the main system image becomes corrupt  or lost. If you choose to use an MSFC2 boot image, you must store it in  the MSFC bootflash.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080116ff0.shtml#sup32
In Supervisor Engine 720, after the Cisco IOS  Software Release 12.2 SX there are no separate image files such as a  bootloader image and the main IOS image. The Supervisor Engine and the  MSFC both run a single bundled Cisco IOS image.
Why do you think the command did not work? Did you check the output of "show boot" afterweards for the value ot BOOTLDR variable?
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
5 Replies 5
Ivan Shirshin
Kind Regards,
Ivan
Kind Regards,
Ivan
Hi Ivan,
many thanks for your answer, I read the update note before I started my exercise and found only a descrition for bootldr for the SUP 2 and not for SUP32.
From you I know that the Boot Img must be stored in the MSFC bootflash is this accessible via command bootflash: ?
Regards Matthias
Yes, it has to be on MSFC bootflash and it is a "bootflash" file system.
welcome!
Kind Regards,
Ivan
Kind Regards,
Ivan
Hi Ivan, Hi all
many thanks here for User my way to update a C6504e L3 Switch
conf t
dir
! delete old Image files : delete sup-bootdisk:s3223-ipservicesk9_wan-mz.xxxxxx.bin
copy tftp sup-bootflash
x.x.x.x
dir bootflash
! delete old boot image files: delete bootflash:s3223-boot-mz.xxxxxx.bin
squeeze bootflash
copy tftp bootflash
x.x.x.x
no boot system flash sup-bootdisk:s3223-ipservicesk9_wan-mz.122-18.SXF8.bin
sh run
sh rom-monitor slot 1 rp
upgrade rom-monitor slot 1 rp file tftp://x.x.x.x/c6msfc2a-rm2.srec.122-17r.S6
sh rom-monitor slot 1 sp
upgrade rom-monitor slot 1 sp file tftp://x.x.x.x/c6ksup32-rm2.srec.122-18r.SX9.bin
wr
reload
Regards Matthias
This seems to eb a correct sequence for ROMMON  + IOS upgrade.
Kind Regards,
Ivan
