12-13-2006 06:54 AM - edited 03-05-2019 01:19 PM
Please can we configure HSRP on 2 switches Cat 6509 with Sup720 on IOS cnnected to easch other to have single gateways for each vlan.
I am told that we have to have MHSRP.
12-13-2006 06:59 AM
If u wanted to configure HSRP u need to have an MSFC card(layer 3) then only it is possible to configure HSRP on your 6509 switches.
once the MSFC card is inserted.
issue the command as....
6509>session 15
which will take you the layer 3 card.
which
configuration looks like below....
switch-A
interface vlan 2
ip address 10.1.1.2 255.255.255.0
standby 1 ip 10.1.1.1
standby 1 timers 5 15
standby 1 priority 101
standby 1 preempt
switch-B
interface vlan 2
ip address 10.1.1.3 255.255.255.0
standby 1 priority 100
standby 1 preempt
on the pc side you need to give the gateway ip address as 10.1.1.1 which is a virtual IP address, which means even if switch-A fails automatically switch-B takes the load.
eg. normal scenario 10.1.1.1 will act as 10.1.1.2,if 10.1.1.2 fails 10.1.1.1 will act as 10.1.1.3.
Note: on both the switches you need to have layer 3 cards installed.
hope this helps.
rate this post if cleared.
12-13-2006 07:09 AM
as posted earlier, you can configure HSRP if you have MSFC on it.
this URL will help you to get overview and configuration of HSRP.
http://www.cisco.com/univercd/cc/td/doc/cisintwk/ics/cs009.htm
hope to help ... rate if it does ...
