11-04-2013 12:11 AM - edited 03-07-2019 04:24 PM
Hi All,
Good day.
I need some assistance in regards to a nexus 2232 fex device.I have swapped the FEX PSU with a local spare. The FEX did not restart after the replacement. I re-seated the second PSU shortly after, and the FEX re-started. Can you please advise if this is an expected behaviour?
The fex is also having receiving a power of 396.0W instead of the ussual 792.00W power.
Thanks and Regards,
Kanes.R
Solved! Go to Solution.
11-04-2013 08:14 AM
No, that is not the expected behavior. The first time you inserted the PSU in the slot, it probably was not all the way in, but the second time was.
11-04-2013 08:14 AM
11-20-2013 06:46 PM
Hi Reza,
Thanks for the update. It was indeed a hardware failure where we had to replace both the PSU's.
Appreciate this.
Kanes.R
