POE Switch power issue AP1200
kian_hong2000
I notice that Access Point 1200 series need at least 48V to power on.
However, I found that when the AP is connected to POE switches, the inline power used drop to nearly 11V.
I thought the power should be 48V of inline power being used. Why the power is cut down to just 11V?
iyde
Level 4
Level 4
Where did you see the drop to 11V? As far as I know the switches do not show the voltage they send out to a PoE device. They show the Watt (W).
Is it posible that you have seen 11W when you did a 'show power inline'? That would match the usage for an AP1200.
