02-27-2012 05:23 AM - edited 03-07-2019 05:12 AM
I have the following scenario i'm trying to solve:
If client gateway = 192.168.64.9 then next-hop = 192.168.64.8 else use default-route 0.0.0.0
I know it's possible to do a route-map match ip-address ACL list. But is it possible to match on gateway?
Some info about hardware and config:
6509-E in VSS (IOS 12.2(17r)SX5) withVS-S720-10G supervisor.
All routes are static, IP for 192.168.64.9 is on SVI vlan.
Solved! Go to Solution.
02-27-2012 05:59 AM
No way to do that with PBR options as far as i know. You would basically have to have a list of all the clients using 192.168.4.9 as their gateway and then use their IPs in the acl for the PBR ie.
access-list 101 host 192.168.64.12 any
access-list 101 host 192.168.64.22 any
etc...
for all clients using 192.168.64.9 as their gateway and then set their next-hop IP as 192.168.64.8.
Mind you as 192.168.64.8 is in the same subnet you may as well just reset those clients to 192.168.64.8 directly rather than using PBR.
Jon
02-27-2012 05:35 AM
What I understand based on your post is.... You want define a route-map and set the default next-hope to route all the packets from a specific network to forward to the defined gateway in route-map instead of going through default route.
If that is correct below is what the relevent cofnig.
interface Vlan18
description ABC
ip address 10.28.28.1 255.255.0.0
ip policy route-map DFE
route-map DFE permit 10
match ip address 171
set ip default next-hop 10.28.28.100
access-list 171 deny ip 10.31.6.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 171 permit ip 10.31.6.0 0.0.0.255 any
Please rate all the helpfull posts.
Naidu.
02-27-2012 05:50 AM
Almost. That is currently the solution we have using.
But consider this, there are some clients on the same subnet which we want to route to a different IP. So we have the following config on the SVI:
vlan x
ip address 192.168.64.9 255.255.248.0
ip address 192.168.64.222 255.255.248.0 secondary
We want to evaluate the next-hop based on the gateway. So if client has gateway 192.168.64.9 -> next-hop = 192.168.64.8 and if client gateway is 192.168.64.222 -> next-hop = default-gateway.
02-27-2012 05:59 AM
etc...
Jon
