02-23-2012 10:00 AM - edited 03-07-2019 05:08 AM
Hi Netpro
i have port connected to server with the command "switchport gurad root" if i want to remove the command did that cause the port to be recycled?
thanks
02-23-2012 10:06 AM
Hello Ibrahim,
Just a backdrop of what the command does for our reference:
http://www.cisco.com/en/US/customer/tech/tk389/tk621/technologies_tech_note09186a00800ae96b.shtml
This command should not "bounce" the interface or cause it to go down and then come back up again.
Pronoy
02-23-2012 10:12 AM
Hi Prono
I dont have cco account to open link provided
02-23-2012 10:42 AM
Ah ok. Well no problems. It was any which way a generic discussion on spanning tree guard root feature. None the less, removing that command from the interface level would not cause the port to bounce.
You can also create a guest account on www.cisco.com and then use those credentials to view this PDF though.
Pronoy
02-23-2012 11:16 AM
Hi Prony
this command on between switches not between switch and Host
thanks
02-23-2012 12:52 PM
Hey Ibrahim,
I do not get the question. Are you trying to understand what happens when you have spanning tree guard root configured on an interface which has a host connected to it?
OR
Are you trying to understand why is it configured there?
/Pronoy
02-23-2012 01:12 PM
am looking for both
thanks
