Remote Span port between 2 x 4506's
simplecisco
I have 2 x 4506's in separate buildings they are connected with a layer 3 trunk and both in different vtp domains.
I need to mirror a port on one 4506 onto a port on the other.
Doing some research it does not look like RSPAN will work I also looked at ERSPAN but it also appears that this is not supported on this platform.
Has anyone any other ideas how I can mirror a port between this two switches?
Roger
Hi Roger,
I just found an excellent post by giuslar on these very forums:
https://supportforums.cisco.com/message/3152750
It may be what you're after!
Regards, Ash.
