Unable to found Voice SSID from Wi-Fi Access Point
Vikrant Ambhore
Hello All Friends,
I'm trying to do a configuration on Cisco Aironet 1200 series wireless Device and I'm having some difficulties.  I have Cisco Aironet Wi-Fi Device, and am trying to configure with two SSID,
One is for DATA & another is for VOICE Triffic, I have two VLAN, one for each SSID, but I Can show only ssid Coinop, If i tried to enable guest-mode on SSID Voice-Coinop then i got error: Guest-ssid already existing on ssid Coinop
I need to Access SSID Voice-Coinop for connecting Wi-Fi Cisco IP Phone.
I request to All Experts Please help me on this issue.
Vikrant
sh run
Building configuration...
Current configuration : 2382 bytes
version 12.3
no service pad
service password-encryption
hostname CiscoAPWiFI
enable secret 5 XXXXXXXXXXXXXXXXXXX
ip subnet-zero
no aaa new-model
dot11 vlan-name Data vlan 1
dot11 vlan-name VOIP vlan 100
dot11 ssid Coinop
   vlan 1
   max-associations 25
   authentication open
   authentication key-management wpa
   guest-mode
   mbssid guest-mode dtim-period 1
   wpa-psk ascii 7 15425F5D557A7D7D7C6762
dot11 ssid Voice-Coinop
   vlan 100
   authentication open
   wpa-psk ascii 7 06565B701D1E5F40514345
dot11 network-map
username XXXXXXXXXXX password 7 XXXXXXXXXXXX
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
encryption vlan 1 mode ciphers tkip
encryption vlan 100 mode ciphers tkip
ssid Coinop
ssid Voice-Coinop
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root access-point
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.100
encapsulation dot1Q 100
no ip route-cache
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
bridge-group 100 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
hold-queue 160 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.100
no ip route-cache
bridge-group 100
interface BVI1
ip address 192.168.8.254 255.255.255.0
no ip route-cache
ip default-gateway 192.168.8.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Forgot adding mbssid to the Radio interface:
no ip address
no ip route-cache
mbssid
Cheers.
jorge.calvo
Try with the next configuration:
dot11 ssid Coinop
   vlan 1
   max-associations 25
   authentication open
   mbssid guest-mode
   vlan 100
   authentication open
   mbssid guest-mode
Hope this helps.
Regards.
no ip address
no ip route-cache
mbssid
Cheers.
no ip address
no ip route-cache
mbssid
Cheers.
Thanks for Help,
It's work Now
