Vlan goes to act/lshut status
shah.chintan
I have 6500 with sup720 with 12.2 IOS running and i have Layer 2 port-channel (ISL trunk) between two CAT running HSRP for some of L3 VLAN.
When I reload any of CAT. After CAT comes up some of this vlan goes to "act/lshut" mode when i do show vlan so that HSRP status for that goes to INIT. I need to do manually "no shut vlan <Vlan number>"
Does any one faced this issue any time ? What is resolution for this so this issue doesn't happen again if i reload CAT.
Chintan
5 Replies 5
royalblues
Level 10
Level 10
Can you post your configurations
interface Vlan11
ip address 10.253.0.2 255.255.255.192
no ip redirects
standby 1 ip 10.253.0.1
standby 1 timers 1 3
standby 1 priority 101
standby 1 preempt
end
interface Port-channel1
description MLS_TRUNK
switchport
switchport trunk encapsulation isl
switchport mode trunk
logging event trunk-status
logging event bundle-status
Chintan
Jon Marshall
Hi Chintan
Apologies if this is really obvious but after you do a "no shut vlan " do you do a wr mem to save the config ?
Jon
Yes Jon I do it.
But my problem is why vlan go to active/lshut whne i reload which should not happen..right ?
chintan
This was later found to be cisco defect and now it is resloved.
Chintan.
