VoIP qos on 6509 uplink ports from 3750 using auto qos voip trust
martyn.hills
I have 3750 switch ports configured with auto qos voip trust command to support voip.
The 3750 have vlan trunks connecting them to a 6509 - I need to correcty configure the 6509 Q0S to match the auto qos voip trust feature in the 3750.
Is there a best practice document for that - or what should the 6509 config look like.
Sample port configs are below
3750 User Port
interface FastEthernet1/0/2
switchport access vlan 78
switchport mode access
switchport voice vlan 178
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
mls qos trust cos
auto qos voip trust
spanning-tree portfast
3750 Uplink Port
interface GigabitEthernet1/0/3
switchport trunk pruning vlan none
switchport mode trunk
queue-set 2
mls qos trust cos
auto qos voip trust
6509 termination of Uplink Port
interface GigabitEthernet2/4
description Port 2-4 MM Fiber to King_Building 12th Floor
switchport
no ip address
mls qos trust cos
amorales
FOr Uplinks is beter trust on DSCP than COS, Also check the maps that AutoQoS create,so you can see how the cos is mapped to dscp and viceversa.
Good reference is SRND for QoS.
