06-29-2018 08:25 AM - edited 03-08-2019 03:31 PM
Hello Guys,
I am using two 6504E switches and want to configure VSS but i have some confusions. I am following cisco Documentation.
And got stuck on this command.
Step 4 Switch-1(config)# router routing_protocol processID
In my case, right now both switches are configured standalone, connected with each other. Switch one is using the static route towards firewall.
Please advice what to write on this command.
Solved! Go to Solution.
06-29-2018 09:08 AM - edited 06-29-2018 09:08 AM
This command is used if you are planning to use a routing protocol like OSPF, EIGRP, etc..
Example:
router ospf 10
router eigrp 20
etc..
If you are using static routes, you don't need this command.
Example:
router ospf 10
router eigrp 20
etc..
