VSS 6509E
The_guroo_2
Level 2
Level 2
Gents
i am deploying VSS and have follwoing equipment
cisco 6509E
Dual redudnant VS-S2T-10G
I have also ordered WS-X6908-10G-2T card for floor swicthes uplink
can someone pelase tell me how i shd do the cabling for VSS (between two switches)
Thanks heaps
Leo Laohoo
1.  You need a VSS heartbeat link.  Recommend you use 1Gbps fibre.
2.  For VSS link, you can use the supervisor's on-board 10 Gbps link and/or combine with 6908 10 Gbps ports.
Reza Sharifi
Also, have a look at figure 4-5 in this link for VSL connectivity with quad sups.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html
Karthick Murugan
Hi Guroo,
You need a Tengig connection from each supervisor module on one chassis to other chassis. Only Tengig connections can be used as VSL links.
Thanks & Regards,
Karthick Murugan
CCIE#39285
Thanks & Regards, Karthick Murugan CCIE#39285
