Community Member
Fereidoun. Fatahiany
Hi; I have recently bought a brand new NM-32A module to use in my lab and installed it on a cisco 3745 router . I can not get the lines Async on it. Do you have any configuration example that I can use please. ?
Here is the copy of the config I have typed on it.
Building configuration...
Current configuration : 1227 bytes
version 12.3
hostname DMVPN/ACCESS-server
boot-start-marker
boot-end-marker
enable secret 5 $1$NGTF$FiVS9ptetakrkKj/3mgFi1
enable password class
ip subnet-zero
ip domain-list cisco.com
no ip domain-lookup
username admin password 0 cisco
no aaa new-model
ip subnet-zero
no ip domain lookup
ip host R1 2001 10.0.0.1
ip host R2 2002 10.0.0.1
ip host r3 2003 10.0.0.1
ip host r4 2004 10.0.0.1
ip host r5 2005 10.0.0.1
ip host r6 2006 10.0.0.1
ip host r7 2007 10.0.0.1
ip host r8 2008 10.0.0.1
ip host R9 2009 10.0.0.1
ip host R10 2010 10.0.0.1
ip host R11 2011 10.0.0.1
ip host R12 2012 10.0.0.1
ip host R13 2013 10.0.0.1
ip host R14 2014 10.0.0.1
ip host R15 2015 10.0.0.1
ip host R16 2016 10.0.0.1
ip host R17 2017 10.0.0.1
ip host R18 2018 10.0.0.1
ip host R19 2019 10.0.0.1
ip host R20 2020 10.0.0.1
ip host SW-3650-1 2021 10.0.0.1
ip host SW-3650-2 2022 10.0.0.1
ip host SW-3650-3 2023 10.0.0.1
ip host SW-3650-1 2024 10.0.0.1
ip host SW-3750-1 2025 10.0.0.1
ip host SW-3750-2 2026 10.0.0.1
ip host SW-E-1 2027 10.0.0.1
ip host SW-E-2 2028 10.0.0.1
ip host ASA-1 2029 10.0.0.1
ip host ASA-2 2030 10.0.0.1
ip host LAN-SW-2031 10.0.0.1
ip host WLC-4400 2032 10.0.0.1
interface Loopback0
ip address 10.0.0.1 255.255.255.255
interface fa 0/0
ip address 192.168.0.251 255.255.255.0
no shut
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
ip default-gateway 192.168.0.1
ip http server
ip classless
The image used is :
DMVPN/ACCESS-server>en
Password:
DMVPN/ACCESS-server#sh ver
Cisco IOS Software, 3700 Software (C3745-ADVENTERPRISEK9-M), Version 12.4(25d), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 18-Aug-10 08:18 by prod_rel_team
ROM: System Bootstrap, Version 12.3(6r) [cmong 6r], RELEASE SOFTWARE (fc1)
DMVPN/ACCESS-server uptime is 2 hours, 23 minutes
System returned to ROM by reload
System image file is "flash:c3745-adventerprisek9-mz.124-25d.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3745 (R7000) processor (revision 2.0) with 243712K/18432K bytes of memory.
Processor board ID FCZ0936721R
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
2 FastEthernet interfaces
6 Serial(sync/async) interfaces
4294967174 terminal lines
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
Configuration register is 0x2101
Kind regards.
Fereidoun. Fatahiany.
160
