PBR fails on supervisior Engine 7-E
Policy based routing (PBR) fails on a supervisior engine 7-E running cisco IOS Release 3.2.1.SG.Packet are software switched and not sent to the next hop as defined in the PBR route map packets are routed to their destination via the IP routing table look up rather than the route map configuration on the ingress queue.
for the reference attached show -tech.
1498
