5320 MCU Bandwidth Question
I have a single MCU 5320. I will have up to 9 endpoints in a conference at a time. Each endpoint will be configured at a call rate of 768. Would there be any issues with exceeding bandwidth specs on the MCU?
Bandwidth
• Up to 4 Mbps with both H.263 and H.264 for each site in all conference modes, including advanced continuous presence
1 ACCEPTED SOLUTION
Default bandwidth from MCU is for individual participant , This means each participant can call on 4 mbps
Following is from help :
Identifies the network capacity (measured in bits per second) used by  the media channels established by the MCU to a single participant.
When the MCU makes a call to an endpoint, the MCU chooses the maximum  bandwidth that is allowed to be used for the media channels which  comprise that call. This field sets that maximum bandwidth, and is the  total bandwidth of the audio, video, and content channels combined.
hth
Kind regards,
Dharmmesh
1 REPLY
hth
Kind regards,
Dharmmesh
335
